Re: Stator and timing belt issues 650 Mercury
Okay so thanks a bunch for the specs Merc. Should've known someone with my motors big brother would know this. Anyway, I checked the specs and the Ohhmeter is giving me .4ohms so she checked out!! Anything I can do to ensure the life of the stator? Can I coat the wire with some paint on insulation or is that a bad idea? I have noticed that some model stators do that, but I dont know if each strand is insulated or the whole bunch...
Oh and Merc, one more thing. When I was adjusting my idle needles on the carbs, you know how you have to slide the screwdriver through the front plate to get to them? There was a spark from the front panel through the screwdriver to the carbs. I guess something is trying to ground out through that path. Does that sound like the stator is in fact sending a charge to the block? Thanks a lot man!
