Zq8 Blazer
- Mar 18, 2012
- 48
The serial # is A923834. It's a 60hp and from the serial # I believe it's a 1985 model and it has been in storage for about 10 years. When I hook jumper cables up to the + and - on the battery it turns like it's going to start, but I get no spark on any of the plugs. Is there some kind of theft feature so you can't do this without a key or is there some other problem I need to investigate? If it's another problem, what might it be?
Also I do not have a key for this, I cannot find it anywhere, what can I do about this??? In the meantime can someone explain to me how I can hot wire this unit? I want to make sure I can get it up and running before I spend time and a bunch of money putting it on my boat. The ignition has the following wires running into it:
yellow/red
TWO blacks
TWO black/yellows
TWO whites
yellow/black
TWO reds
yellow/red
TWO blacks
TWO black/yellows
TWO whites
yellow/black
TWO reds
