Hello everybody,
My Mercury with only 180 hours on it some time ago started a noise something like a shot bearing mostly recognised at idle rpm.When i took the boat out and run the engine on muffs the noise was much louder almost sure that something was broken at the height above the lower unit.I took the lower unit off and i found the plate below the exhaust tube broken(http://www.**********/parts/search/Merc/Mercury/2010/1E30453KZ/DRIVESHAFT HOUSING/parts.html).I can't imagine why this thing broke down.Anyway ,trying to reinstall the lower unit i had a problem.Although i took care of the splines of the driveshaft and the gear shaft and the waterpump tube the lower unit didn't go all the way in(about half an inch stayed out). I tried also without the white plastic bushing of the gearshaft in case this was the problem but again nothing.
My reinstallation efforts were at neutral gear.Do you have anything to suggest before i try with forward gear as i did with mercruiser A1?
