Re: 50 hp starter
Re: 50 hp starter
You will need to look inside that starter, either the brushes have worn or the brush holder has corroded to the point that the brushes are hanging and not free to slide in against the commutator.
You may get lucky and just need a new set of brushes, lightly sand the commutator and add a drop of oil/grease to the bushings.
Or it may be corroded so bad you need a new brush holder assy
Or you may need to replace the starter.
Until you look, we are all just guessing.
