jopaped
- Mar 10, 2012
- 9
I purchased a 1995 mercury 8 hp as a stronger kicker motor for my boat (I currently use a 2 hp). The 8 hp starts up easily when the choke is on. When the choke is disengaged, the motor will start to run rough and will eventually stall. The engine will stall instantly when I put motor in forward gear. The motor has good spark, water pumps good through the tell tale. I cleaned out the fuel filter already and I am using fresh gas. The guy I purchased the motor from last used the motor about two years ago. I'm thinking about pulling the carb for a good cleaning. Am I heading down the right road? Any suggestions would be appreciated. Thanks,
John
John
