This weekend i am picking up a used 75hp Mercury!
Questions:
1) Can i lay the motor on its side in back of my SUV? Does it matter what side?
2) Do you think the bolt pattern will line up to the mercury? The motor on there now is a 2000 50hp johnson, going to a 2002 75hp mercury? If it doesnt mount up should I buy a plate for the back and use the old holes? Or fill the holes and drill more? ( what would you use to fill the holes with?)
3) do you think a motor lift for a car will get the motor high enough to mount on the transom?
thanks
Questions:
thanks
