HVACRat
- Aug 6, 2009
- 31
This is my first Mercury outboard, she is a 1988 20HP, tiller steer pull start engine. I bought this engine about a year ago and she has ran like a champ until now.
About a month ago I got off in some water I shouldn't have been and bent my prop shaft; I replaced the prop shaft (which was very easy by the way!) but now I have another problem.
This weekend I put her in at the ramp and she didn't start on the second or third pull; this has never happened so I knew something was up. What I found was one of the two wires that come from the stator to the power pack had ended up against the exhaust housing and melted the insulation causing a short. I cleared the short but still had no joy.
I called my boat guy and he said it was either the power pack (shorted) or the stator (shorted). Since I was 'on the water' (this was during our Extreme Hunt!) all weekend he ordered the power pack, I received it Friday and installed it... Still will not run.
I am going to pull the flywheel and check the stator next, at home now, and see if I can make heads or tails of this.
What I really need to know though is the basic sequence of operation. I am getting fuel and spark to the plugs/cylinders but she will not start...
Spark is made in the stator, then...
Spark goes to the power pack, but I don't know what happens in there...
Spark THEN goes to the coils, again, I don't know why...
Spark THEN goes to the plugs.
The question is what do all these components do along the ignition sequence?
What is the best manual for this engine? A friend says Clymer is very good but I also want to know if I can get a 'factory' manual that is model specific; and if so where?
Any thoughts on my ignition problem will be greatly appreciated until I can get my hands on the correct manual.
BTW, I LOVE this motor; it fits my hull perfectly, the grip shift is GREAT and until this little problem (which I should have noticed a wire out of place against the exhaust housing!) has never left me in doubt about getting home.
