I been working on this motor and got it running fine thanks to this website but now I have lower unit problems. I thought it was the prop shaft seal so I just replaced that. Took it to the river and ran it in the water and you could tell exhaust was blowing out lower unit oil. I let it sit and there is definitely lower unit oil draining down from the exhaust and water in the oil. Would shift shaft seal cause that or drive shaft seals????? It's the inline 6 115 hp.
