Here's my problem:
Voltage at the control box drops intermitenttly from the full 12V to ~5V. This is a problem because the control box does not have enough power to activate the starting solenoid when turning the key to crank and start the engine.
If I hotwire the engine (key in on position - manually bridge the starter solenoid with jumper cables) it starts and runs, but the control box still reads at 5V.
This does not always happen though; When the boat is on the trailer or when I put it in the water for the first time the control box has 12V and starts the engine up - no problems.
Here's what I know:
I cannot seem to replicate this problem on the trailer - the control box always reads 12V.
Is this a symptom of a bad switch box? rectifier? or is the problem in my control box?
Thanks for any responses.
Here's what I know:
- Battery reads 12V at the terminals
- Battery Cables read 12V at the starter solenoid (this reading is consistent with the control box when there is the full 12V at the control box and when there is only 5V at the control box)
- Rectifier output is 3.6V when in neutral (800RMP) - Control box reads ~5V (wasn't able to get a reading when the control box had 12V)
