I have a 2001 Mercury 200HP Saltwater EFI. The boat was running fine and the last time I ran it, noticed the engine started to sputter and eventually shut off. Then the engine did not want to start back up. I could choke it and it would start; however the moment I put the engine in gear it would shut down.
Pulled the cover off and noticed a gas and oil mixed sludge on and around my fuel filter and realized something was wrong. After about 30-40 minutes of waiting, eventually got the motor to start and back in gear and idled back to the dock and loaded boat.
I removed the fuel filter and everything in it looked fine and definetely not leaking so put back on. Also removed the inline oil resevoir and re-attached and everything looked fine there. Any ideas of what I should check next or trouble shoot. Everytime I start the engine I notice the leak but can't pin point where it is coming from. Here are some photos:
Any advice and feedback is much appreciated before I take to a shop.....
