I have a Mercury 40 2-Stroke 4cyl 1991 Classic, only owned the boat/engine for a couple of years and learning slowly.
At the end of last summer while on the water I noticed more exhaust smoke than usual on the boat and after inspecting the outboard found that there appeared to be exhaust smoke and warm water spattering out of the front of the engine just under and around where the steering pivot arm enters the engine. Then paranoid .... I noticed on the rear of the engine opposite this there was oil spatter coming from the 2 exhaust ports leaving spotting in the water - there appeared to be white emulsified oil on the lower edge of these ports also - myabe this part is normal but the exhaust gas and water issue definately seems wrong.
It's been suggested to me that I may have a top and bottom crankcase seal Leaking or blown powerhead and adapter base gaskets. Someone also said that it could be the grommet at the bottom of the exhaust tube ?? Or even a damaged exhaust adapter plate ?????
I hope that there might be folks out there with experience of this or these engines. I would like to tackle the repairs myself but would just like some assurance that I'm going in the right direction before I do so. Also does anyone out there have a nice detailed procedure for this ??
Any help/advice appreciated.
Cheers
Picture below :
See Engine Details : http://flic.kr/p/bvY7Bn
Cheers
