2 stroke/injected with 300 hours. I've replaced fuel line, bulb, spark plugs and fuel filter, drained tank and filled w/ fresh gas and marine stabil and the tank vent is open. The last 6 times out the following consistnly happens:
Runs great at full RPM's (5000) for about an hour, then suddenly dies. It starts right back up, but will only run up to about 2400 RPM's. If I try to throttle up past about 2400, it wants to quit, but keeping it around 2400 or less it seems like it would run like that forever. The last time out I had to go several miles back to the dock at the slow Rpm's and could not throttle any higher. After sitting off for about an hour it still would not go any higher. The next day the same thing repeated after running OK for about an hour.
This is very frustrating. I'm ready to buy several parts to chance at the same time or possibly take it to a mechanic for help. Problem is you need to run it hard for an hour to test!
Suggetions? Like I said, I'd buy/change the most likely.
Thanks. RR
Thanks. RR
