superduperest
- May 19, 2011
- 17
Hi, recently i bought new fuel lines and primimg bulb for our engine and replaced the connector that attaches to the engine itself. when i pump the bulb fuel wont get into the engine. the engine starts when sprayed with easy start into the carbs so its not an engine fault as far as i can see. The bulb is on the right way, the fuel pick up in the fuel tank is clean and unblocked but still the bulb wont go hard and therefore the engine wont start, needless to say that this is making me a little mad. ive tried unpluging the fuel hose from the engine and then pumping the bulb, doing this causes fuel to squirt everywhere so it all seems to all be connected properly
Any suggestions would be appreciated
Thanks in advance
Chris
Thanks in advance
Chris
