Tofuminator
- Feb 5, 2012
- 18
I acquired an old merc and at first it ran but after not even one hour of total usage it would not start. I had a boat mechanic look at it but I didn't want to proceed after being $150 in the hole for repairs and labor. HEre's what's been done so far:
1. Carberator rebuild kit
2. New fuel hose 3/8 inch and brass fittings for the ends
3. New primer bulb 3/8
4. New plastic gas tank with all the right conversion adapters from West Marine
The mechanic said the fuel can be seen spraying into the carburator when you prime it, but he did not have the tools to check the compression on an older model like this. He gave it back and said a last stride would be to replace the gas tank.
Today, with the new fuel setup I bought. Primed the fuel and the bulb is hard, With choke on and motor in neutral, after close to ten pulls of the rope the motor started and ran for approximately 10-15 seconds.
Repeat, motor will start I placed it in gear and it runs for 15-20 seconds. LOTS of smoke and it seems like the motor sounds like it's gasping for air.
The motor sometimes won't even start after 20 pulls, when it finally does it will just die out after 10 seconds or so. What could be wrong? IS it even worth fixing this motor? There is a Nissan 10 hp 90's model motor for sale for $500 and i'm wondering if I should just buy that as opposed to putting any more money into the OLDMERC....Please any help would be nice.
