Can't get the exhaust housing apart from the powerhead, hanging from the crane 3 days now, pry bar and plastic hammer for hours, nothing, it does not move at all. All 10 nuts taked out.
Aww hell. So you have the powerhead out of the case, and the lower unit off? It is just the exhaust tube that is against the powerhead? The gasket that holds the two together is very sticky, and often gives a hard time splitting it apart. Did you try torching the upper end of the exhaust housing. If so I'd hit it with a propane torch until the gasket gets nice and sticky, and then slowly pry her apart. If you have in fact removed all the screws she should come right apart.....
I try one of those portable torch from Home Depot for about 30 minutes, after that I lay down it in the floor with contact only over 8 inches of wood in the upper powerhead and the lower section of the exhaust, step over the place where both stick together and jump several times (I'm 240lb). Nothing, this frigging thing is welded. I will try to loosen the studs one by one before trying anything else.
Anyway you could get us a picture?No joke, I'm aplying PB Blaster for 2 days now, will try to take the studs out on the weekend.
That is cool to know. I have never heard of that before!Might try the local auto supply store and see if they have a newer spray called Frezze Off. works like PB Blaster but frezzes the stud and shrinks it as where heat will expand the metal. It has worked for me removing pressed in parts that would not fit in a press.
Oldman570
