Hello all,
I've got a 2005 merc 50 HP, and I just changed the impeller, gaskets, etc. According to the manual (seloc and mercury), the torque spec on the housing bolts is supposed to be 60 in-lb. I torqued them to 40 in-lb, and already noticed some deflection in the housing. Should I keep going, or stop there? I was using the threadlocker on the bolts, as recommended.
Thank you
Thank you
