OK I have a a 1997 Mercury 75HP two stroke the 75ELPTO , the motor have 120psi compression, it fires right up, and I can say that it runs fine at idle, ....carburetors and fuel pump just rebuild, new plugs, clean fresh fuel , but the motor sounds under accelerations like if a cylinder is no firing, or low spark, but after doing the the finger test ,no recommended to persons with a bad heart, there is spark, I also took the tests light and pinching the boots, in other words shorting to ground the cylinders, two and three the motor basically won't react at all, but when pinching the N1 it dies right away...I haven't try the boat in the water , so I can't say if it runs fine or not in the river.. any suggestion.. thanks
