terrencemclean
- Jan 10, 2008
- 19
i bought this motor under the assumption it "runs good"
but this is what i have so far.
i turn the key to the on position and then i hear a short beep, which is standard or "usual" but then a few more seconds, there is one long continuous beep.
after the long beep ends, i can see the fuel lines get soft again. (no pressure in them).
the motor will start, but not for long.
sometimes it will start and the idle will go up and down, up and down and then shut off.
i have no idea what is wrong with this motor or what the long continuous beep means.
please help.
2008 mercury 90hp 4stroke
compression 210psi on 4 cylinders
good spark on all cylinders
fuel injectors are clean and in working order.
please help.
