Hi --
The question is, what voltage is used to energize the fuel injectors?
Background:
Condition: The engine has 287 hours on it and ran fine before I stored it last year. I put in gas stabilizer, ran the fuel down and oiled the cylinders. Now the motor runs rough and hesitates when accelerating. It does not have enough power to even get on plane.
After checking/replacing the following:
all new gas
battery is strong
checked fuel pressure at 1500 RPM- steady 41 psi
checked spark - strong on all four plugs and steady timing
checked and reseated connecters for the electronic Control Module - OK
replaced spark plugs
replaced external fuel filter
replaced internal fuel filter
verified primary and secondary resistance for both coils - all good
cleaned the HP fuel-pump filter and VST - not very dirty
Since I don't have a voltmeter with a direct voltage adapter, I can't do some of the electrical tests identified in the manual.
I'm going to clean the injectors. Since I have access to a heated ultrasonic tank, I'm going to do that myself. In order to best clean the injectors, I need to energize them while they are in the tank. that's why I need the voltage.
Thanks,
Qack
Background:
all new gas
battery is strong
Thanks,
Qack
