Quick question (hopefully with a simple - cheap answer!)
1993 Mercury 175 outboard.
When not in gear, the motor seems to operate fine. Revs up to 5000+ RPM with no discernible problem.
Put it in gear, and the RPMs won't go above 2000, and of course the boat has no speed.
This has happened before (both times after sitting - neglected - for long periods of time)
Once a long time ago, we had the carbs cleaned and rebuilt and all seemed well for a while.
The last time, I had the carbs cleaned and rebuilt again and the tank drained. But it didn't correct the problem.
It just seems starved for fuel so I'm going to change the little in line fuel filter (I've already changed the water separator filter).
Any other ideas?
I took a video the other day and I'll try to get it posted asap.
Thanks!
Any other ideas?
Thanks!
