Hey guys,
Hoping that someone is able to help me with my problem on my 01 Mercury 25hp 2 stroke tiller shift. Problem I have with it originated one day out on the water when it was really tight to shift back into neutral from forward, as i had to basically force it in to neutral it sought of slipped and stayed in gear and wouldn't come out of forward even after turning the handle.
After a bit of inspection after, all I noticed what could be the problem was that both the throttle cables that go from the tiller handle around to a cog/pulley on the other side of the motor were chewed out and badly frayed. So after replacing both these cables with new I still have the same problem, it will start but will only start in gear and will not change out to neutral or reverse.
Has anyone ever experienced or had this happen to them?? Or does anyone know what could be wrong with it? Any help will be appreciated as hopefully it will stop me from pulling the rest of my hair out!
Thanks
Thanks
