DangerRanger44
- Dec 6, 2011
- 1
I have a 9.9 mercury two stroke. Two days ago on the lake the motor would not run at wot. The engine would choke itself out unless I shifted back into neutral. It then started smoking out of the driveshaft housing and leaking oil into the water. The oil was brown which I thought may have been unburnt oil coming out of the exhaust from a rich fuel/oil mixture. I drained the lower unit and did not see water but the lubricant inside came out completely grey. I was thinking possibly the prop shaft seal was leaking but wanted to see what the experts thought. This is my first boat and I am completely new to Outboards.. thanks for the help!
Sent from my ATRIX using tapatalk
