monark1800
- Dec 1, 2011
- 16
Last Monday, I launched my boat, pumped the ball a couple of times, then tried to start. No fire, pumped the ball,still nothing. Repeated this several times before realizing kill switch was off. Boat immediately started.
The water was rough, so it was a long low RPM ride to the fishing spot. Later when I tried to run fast down the lake, the motor would bog down, then rev up and down. Eventually ran fine.
Saturday, I took it out in 35 degree temps. Not running very hard because of the cold. Boat started missing real bad and cutting off. I found if I bumped choke it would clear up momentarily. Loaded up and went home. Changed ball out because it wouldn't get hard. Boat started,
Help!! missed badlythen wouldn't start. Changed plugs, still won't.fire.
