Re: impeller install ?Mercury 9.8 HP.
My Dad is working on our 1984 Merc 9.8. I was helping him (not very much) by staring at that same impeller bolt, wondering why it won't simply slide up and out of the pump like the manual implies that it should lol! He has already been trying to yank it out with needle nosed plyers, but I can tell that ain't gonna work! Thank goodness for the power of google and your post which I just printed this out for him. He's pretty good with chisels - I'm sure with your inspiration he'll have it off in no time
Ok Houston, we have a problem.
He tried the chisel approach, and the impeller bolt went
down the shaft a bit.
Anti-progress being made lol!
Trying again to use the needle nosed plyers to pull it up isn't working. So, we know that it slid down, but we can't get it back up to even where we started, let alone right off. Here is a pic:
A question my Dad has is "should we be able to slide it straight up without having to rotate it at all?".
He is asking that because in the Seloc manual, in the "assembling type B" section, it says "Position the impeller drive pin on the driveshaft. Slide a NEW impeller down over the driveshaft. Position the impeller drive pin groove approximately 1/8 turn COUNTERCLOCKWISE from the impeller drive pin. Exert a downward pressure on the impeller and at the same time rotate the impeller clockwise and slide it down over the drive pin".
We have no idea why, when assembling, that method of rotating is required. I mean, why no just align the drive pin groove with the drive pin all the way? So, we don't get that, and maybe that rotating needs to be done also when removing the impeller?
And a question that I have is, if we do seriously try removing that collar/nut with a chisel, can the downward force exerted on the collar/nut cause problems down below?
Thanks!
