Just redid my fuel lines, new bulb, and rebuild fuel pump on my 1992 mercury 115 4 cyl. Put it on the muffs to start it up and make sure everything is running good. Everything was fine, but I had the cowl off to look for leaks and noticed this spot where water was coming out of a little hole on the back of the engine beside the plugs. I dont think this is right for water to be coming out under the cowl and on the back of the engine like that. But everything was running right, and water pump pumping good. I even put my finger over the hole and it stopped the water as it didnt feel like there was much pressure, and didnt make any difference? Everything seems good but this leak if anyone can shed some light on whether this is correct or not, and if not what is the proper way to fix???
Thanks in advance.
Thanks in advance.
