Re: Grinding when shifting forward/ Mercury outboard
Ig you mean that you were turning the prop while a helper shifted the control and the drive DID NOT lock into gear until you pushed the linkage forward, then the cable housing is indeed worn, and not forcing the cable to pull the correct length.
Cable replacement is pretty straight forward, disconnect the cable and housing from the motor, the control box needs to come loose to remove the back plate and disconnect the shift cable.
Remove the cable from the boat, note how well zip ties are used to hold it into place as you will want to secure the new cable close to the same.
The cable will have #'s inl stamped into the housing near one end, your parts place will need these to get you a replacement assy.
Reinstall the new cable to the control box first, with the control remounted and in Neutral, attach the motor end and adjust so fit in Neutral.
Again, have a helper shift the control while you turn the prop to check shifting both Forward, Neutral, and Reverse. You may have to make slight adjustment to the cable to lock both Forward and Neutral.
