Re: What fuel mixture for 2001 115hp mercury 2 stroke salt water series
Good point; however, just for argument's sake, how much Wide Open Throttle do we do on a 115? In my experience, maybe a few minutes a week, no more. On my 17.5 ft boat, a comfortable well-planed cruise will be at 3,000/3,200 RPM. Beyond that, it would take a very flat sea to go WOT. That doesn't happen every day. 50:1 is really a bit smokey. Let's do something for the marine environment! Lean is clean!
Jut one word of caution, WildCard: if you plan to use the autolube feature, make sure the oil pump is thoroughly checked and primed beforehand. I would be concerned if the previous owner never used it, because inside, the pump is composed of two nylon gears that are driven off the crankshaft. Those gears don't like running dry for any extended period of time. And priming the oil circuit is of essence, because the gear pump hardly creates enough vacuum to suck the oil. Don't assume that the oil will travel on its own just by filling the oil tank. The circuit has to be filled beforehand.
