Hi All,
I'm trying to replace the water pump for my 2008 2 stroke Mercury 50. I'm only able to pull the lower unit about one inch apart from the engine after loosing the 5 nuts/bolts. Now I've put it back temporarily. Should the gear to be shifted to a certain gear (e.g. reverse) before removing the LU at the beginning? In order remove the lower unit, how and where to disconnect the wiring connections? I've watched serveral youtube videos on replacing the water pump; however, they did not show how to disconnect the wiring prior to taking out the LU.
Looking forward to your reply..
Thanks.
Tom
Thanks.
Tom
