Re: sea foam,starting fluid
Yes on Sea Foam, specifically formulated many 10's of years ago (for OMC as the story goes). It contains a couple of chemicals which clean fuel up and help to prevent water problems but it also contains oil. So, in spraying it into the carbs a 2 cycle engine, unlike starting fluid it will lubricate as it helps your engine to start and clean up varnish and all the bad stuff.
I don't measure it. If I think I need 3 times the recommended dosage on the can (1 oz per gallon) I put it in. I learned of it here on iboats and bought my current boat in '04 with the engine being an '02. I have never had the carbs off and never had a bad fuel related malfunction. Only malfunction I had on that engine was a temperature sensitive CDI/CDM and a blast of stupidity on my part where I decided to tweak the slow speed jets and shouldn't have.
They have (the site has) a "decarb" process on here where you put in a heavy, heavy dose, let it sit for 15 minutes, crank it back up and run [you run, get up wind and do it at night so the neighbors don't call the fire department (grin) ]....from the oily exhaust. Then change the plugs and go with the recommended dosage.
HTH,
Mark
