hawlisjawt
- Nov 2, 2011
- 9
Hi,
Made a compression test before motor treatement (sea foam) just to compare after.
Made my test after the motor is warmed.
Tested it at ilde and WOT.
Get the same result 120 and 125 psi to the upper and bottom cylinder. idle and WOT..
I heard that im supposed to get higher result at WOT.
Refer to my manual:
"A reading below 120 psi may indicate a total engine wear problem"
I want to know what ive made wrong or if evreything is normal due to carbon deposit.
Thank you.
Refer to my manual:
Thank you.
