Re: mercury 150 efi fuel pump
can you tell me the part in need to test the fuel pressure? i assume it connects to the brass valve on top of the VST, correct?
You will need a fuel pressure tester guage, either rent one from a auto parts house or buy one a Harbor freight for $25.
does the engine need to be running to test pressure or just the electronic pump in the VST?
Just the pump....below is how to test pump.
(1) Install fuel pressure guage
(2) Prime engine using fuel primer bulb.
(3) Turn ignition key switch to ?On? position.
(4) Operate electric fuel pump for approximately 10 seconds.
NOTE: Fuel pump will only operate for approximately 30 seconds. By turning the key switch to ?OFF? and then back to ?ON? the pump will operate for 30 seconds more.
(5) Take reading on fuel pressure gauge.
Results: If pressure reading is 34 to 36 psi (234 to 248 kPa), the electric fuel pump is providing
fuel with enough pressure to be used by the injectors. Pump malfunction is not the cause
of EFI trouble. If fuel pressure is well below 34 psi (234 kPa), fuel delivery to electric fuel pump, mechanical fuel pump failure or other related problem exists.
if it turns out to be the pump driver, do you know the cost of that part?
A new Merc ECU is about $1900 but if it turns out to be driver I would send it to to Tony Brucato @Brucatosvs.com and have it tested. If it is bad he has a aftermarket for about $1200(I sell these to customers and 100% satisfied with unit)
