After a 3 week lull I went to start motor (had been in water all that time) and got only a quarter crank from starter engaging. Cable connections were tight and clean, and and battery was at full charge. Continued to turn starter key and engine turned over and started. Ran engine for about 2 hours straight without any stop/restarts. The next day attempted to start engine and repeatedly got only quarter crank from the starter. Finally gave up. In pulling cables off of battery terminals, both were very hot. My conclusion is that the starter is toast and I have ordered a replacement Arco starter. My questions are (1) How difficult a job will it be for me to replace the starter? (2) What else should I be replacing at the same time besides the starter? (3) What tips do you have for installation such as greasing and ensuring that the starter shaft engages correctly?
