fisherman81654
- Sep 5, 2011
- 135
Serial# A137316
I have (a ) manual,its in pretty rough shape,so I don't know who made it.
Anyway,it says in the manual to set cranking timing to 22 degress BTDC to obtain 20 BTDC AT WOT.
Anyone know for sure that this is correct,Sure,I want it to run great,but I don't want to blow the engine and if that is the correct setting ,should I go a little bit more or less on the safer side.
I had a idle module that I disconnected because I heard when they short out,your motor gets fried.
thats why I need to set the timing. I read in a post where someone said to take off the prop before cranking.
Is this necessary? This is the first time that I have timed any thing.
Thanks.....
Thanks.....
