Re: should my hand pump primer in line stay hard on mercury xri 220
It doesn't need to stay hard, but it shouldn't need several pumps before the next day. There's 2 check valves in the primer bulb itself that often get bad.
During normal running, it'll be soft, but should not collapse. If you shut off the engine, first squeeze should firm it right up. If it doesn't you have a leak or a bad primer bulb or both. Usually it's best to replace the whole fuel line/primer assembly at once.
hope it helps
John
