mitch_houser
- Aug 26, 2011
- 21
Having problems getting my gearing back in sync after a water pump replacement.I can get it to go foward only and neautral but no reverse.The shift linkage feel out while trying to see what direction the shaft would turn the bottom gear shaft.I can see that there looked like a set screw was on the top of the shaft.With every thing in place I can put my fingers on the shaft and feel it move when I go inot foward but seems like its just not moving when I go into reverse.I'm asking if the bottom cowl can be removed so I can see the linkage I think thats where my problem is on crowley marine schematics it shows the bottom cowl and th elinkage but is this a easy remove to just see?Oh one more thing I've tryed the gear shift in forward and in neatral putting the lower unit back on with the gear on lower unit in one or other direction just no luck so far should the gear on lower unit be in neatral and the hand control when putting back?Thanks in advance Mitch
