1962 merc 700 70hp shifting problem
mycrx
i have a 1962 merc 700 70 hp. i removed the lower unit to replace the impeller a couple weeks ago. i put it together and everything was fine. took to lake several times. i decided to replace the housing since it was glued together. so when the new parts arrived i removed the lower unit agian. replaced everything and put back together and now im stuck in forward. i have taken apart moved the shift rod around reinstalled and still stuck in forward. i have done this about 6 times and still gears arent where they sould be. can anyone help? thanks
merc850
Re: 1962 merc 700 70hp shifting problem
As long as you didn't pull the shiftshaft out of the cam in the LU this should work : Turn the LU shift shaft by hand counter-clockwise until it
stops, then with Vise Grips tight on the bottom of the shaft turn it a
few more degrees CCW until it clicks into a stop, this
should be neutral - check by turning propshaft --
do not shift into reverse unless you turn the propshaft at the same time.
If it is in N go ahead and attach LU to driveshaft housing with control in N.
mycrx
alright so its been awile since this first post. but the weather is getting better and i got problems agian. so i got all my gears to work properly last trip out. now last week i was changing the plastic pick up tube since i cracked it last time. and i forgot to make sure it was in nutral befor i took the lower unit off. and now my cams wont lay together when its in neutral. from what i rember they layed flat before in netural. im i wrong?? i have looked everywhere and just cant seem to find a manual for my or at least that matches the LU. i have got alot of help here before thanks everyone.
carholme
Your s/n from a previous post comes up as a 1961.
Merc 700 Gear Shift 70 1413611 thru 1436114 1961
From here:
http://store.oldmercs.com/category_s/2687.htm
Parts listing:
http://www.crowleymarine.com/mercury-outboard/1103.cfm
Here is the condensed version of the service manual:
http://web.ebscohost.com/serrc/pdf?...8-9124-20be38716669@sessionmgr11&vid=4&hid=10
Copy this to your computer as the link is only valid for a short period of time.
Not too sure what you mean by "and now my cams wont lay together when it is in neutral". Are you talking about the reverse lock cams which fit on the shift shaft? How do you mean they won't lay flat together. When they are assembled the ears on the upper cam fit into the valley on the lower cam.
Gerry
mycrx
IMAG0029.jpgyea i mean the reverse cam lock. the ears wont lay together when its in netural. thanks for the links a couple helped alot. i was told by a local shop that it was a 1962 but they werent sure. here is a picture of what i mean. i know its in netural i can go from forward netural to reverse with moving the shift.
mycrx
View attachment 135805yea i mean the reverse cam lock. the ears wont lay together when
its in netural. thanks for the links a couple helped alot. i was told by a local shop that it was a 1962 but they werent sure. here is a picture of what i mean. i know its in netural i can go from forward netural to reversewith moving the shift.[/QUOTE
Alright so I finally got it. I think. I just went ahead I put it together and seems to shift fine now. We will get a real test when it warms up.
