Re: 1000 mercury kiekhafer 1964 runs fine with muffs on but when put in water stalls
Good idle on the hose and dying in the water is often caused by too lean idle mixture.
Make sure the carbs are clean, adjust idle mix on the hose to best idle PLUS and additional 1/4 turn out. That should get you close enough to get in gear on the water where you should readjust to best idle,, again, best idle PLUS enough more for crisp acceleration, often almost an additional 1/8 turn out.
