Dropped lower unit to clean out metal shavings and install follower kit cam and spring. Noticed drive shaft not turning pinion gear when turned. Any tips on removing water pump and procedure of removing drive shaft? Gear housing casting number 1674-814247c
Thanks,
Craig
Thanks,
Craig
