arkansashunter
- May 4, 2011
- 35
Hey. I have a 1992 mercury 25 that i just put a new switchbox on. It has mechanical timing advance.
It starts up and idles great but when i increase the throttle it dies. At first i thought cdi may have sent me the wrong switchbox but i swapped it for a mallory and it does the same thing.
The odd thing is when i removed the throttle advance linkage under the flywheel it reves just fine. What would be causing this? Before it ran just fine.
There is a picture attacted showing exactly which linkage it is.
I added a charging coil to the motor, Could that be causing this?
Thanks
Thanks
