gschultz05
- Aug 15, 2010
- 24
i have a 1986 champion bass boat with a 175 blackmax outboard on it and the problem i am having is this..... took the boat out 2weeks ago and the boat ran great then last week took the boat back out and as soon as it fire off in the water i could tell something was wrong.....the engine was missing.....got back to the house and fired it up and found 3 dead cylinders, cylinder #2,3, and 5.... checked the obvious and found spark on all 6 cylinders. checked compression and had 125-130 on all 6 cylinders. suspected trigger and changed with no difference on the outcome. changed rectifier with no difference. reversed coils for 1 and 2 to 3 and 4 to isolate the problem and same cylinders still dont fire. checked plugs and plugs are wet so there is fuel getting there......any ideas or help would be great.......
thanks
thanks
