daytripper7
- Sep 19, 2011
- 3
I just purchased a 1999 200 Mercury EFI. Here is the problem... Engine Ran beautifully for 10 hours.... then after sitting for an hour I started engine and applied the throttle and started moving at about 5 mph and then just as I am pushing the bow up and trying to move it just dies and sputters to stop. At first I thought I ran out of Gas, but fuel tank was 1/2 full. I tried to get boat from idle to more than 5 mph but as I can feel the engine start to slightly miss and run a little rough as I try to get it moving. I can actually feel the weakness in the engine as I push the throttle down. It seems as if I was pushing the throttle farther down than normal. However, the engine just could not get passed low idle speed without just dropping out and sputtering to stop. At the same place eachtime as i am trying to get out of hole the boat just sputters to stop and dies. Cuts out>>> I got towed back in due to my ignorance in marine engines...Any Ideas? in talking to local mechanics they have thought it was either the mechanical baker (mechanical) fuel pump or the Electric Fuel Pump (high Pressure). Any suggestions would be appreciatted. Thanks
