dandreye
- Oct 19, 2007
- 141
Hi All,
My 2000 Mercury 90 ELPTO (2-stroke) has been dripping oil when left trimmed up. It is a lot better now that I replaced the O-ring on the filler plug - yet still didn't go away completely. Are these outboards supposed to be completely dry when trimmed up? There's reportedly a defect around the low oil alarm sender attachment in the oil tank for some outboard models - has anyone ever had oil dripping because of that?
Also I've just learned that it could be the leaky gasket at the bottom inside the attenuator plate as the latter is designed to collect the oil coming out of the carbs when the engine is trimmed up and then pour it back into the lower carb when the engine is trimmed down. How realistic does that sound? That, if true, also explains a lot of blue smoke every time cold engine is started after a while.
Searching the forum on "oil tank" as recommended in other oil leaking related threads did not provide the answer.
Many thanks,
Dmitriy
Many thanks,
Dmitriy
