SO i tested the new motor i bought it will start first time but then die right after. Then i try to restart it it will not start unless i high idle it. Starts but well not idle. So i give it a little gas then put it in fwd. Runs fine at about 2500rmp then bogs downs at high rpm but will some times run fine at high rpm WOT...
Still will not idle after runing it for about an hour. Bogs down a lot at high rpm what could be the issue water pressure ok.
