I have a 1978 Mercury 800. It runs great once the boat gets moving. The problem comes from shifting from Neutral into Forward. Reverse seems just fine and never stalls.
Currently, I have the idle set a little high (800-900rpm) hoping that would help w/ the issue as if I give a little rev on the controls while shifting into gear it goes fine. Recommended RPM is 550-650 at idle. I'm just worried w/ revving I am putting added stress on the gearing. I also raised the idle because when the controls were set to neutral it would die at idle.
Now, when I bought this there was old gas in the tank. Very small amount so it wasn't worth me draining it. I'd imagine it's probably all run out by now but perhaps that's one issue? After running it for about an hour yesterday I shut down so we could hang out a little and relax. When I started it back up it no longer stalled when shifting. However, pulling into the ramp it stalled.
Where do I start with finding the issue? The carbs (according to PO) were rebuilt recently. How recently? I don't know. As well as it runs I can't imagine that's the issue.
