1989 150 black max, drove 3 hours to the lake fires right up take off look at temp gage and it keeps going up, so i stop and check pee streme shows to have good water flow and the temp comes down, take off again dose the same thing and its not running right so i stop pull top and gas is just running out the bottom carb could this cause the heating problem because its getting more gas and not enough oil
