michaellawre
- Aug 30, 2011
- 3
I have a 1992 15hp Mercury outboard Model #OG171558 that was running okay, but suddenly stopped. Upon checking the fuel bowl, I noticed some junk so I dumped it out and replaced the fuel, tank, and lines etc. I still couldn't start the motor so I took it to a boat mechanic who rebuilt the carburetor - still no luck. He replaced the stator, coils and power pack (Switchbox) from a spare motor without any luck. It improved the spark but still no start. I purchased a power pack for $196 that I can't return, based on his recommendation and still nothing. He tested each cylinder and said they each have 90lbs of compression.
I took it home and removed the side cover to look into the pistons and found a little carbon build-up on the top of the pistons and a little piece of a red gasket?? in the top peep hole and a fairly large piece of a black gasket (from the carb??) in the lower piston peep-hole. After pulling the rope to slowly look at the rings and pistons there is plenty of oil/gas coming through into the piston. It has good fuel in the cylinders and a strong spark (with new plugs). Now after spending over $450, it still doesn't run. It seems like it should run but nothing more than a few putts with a little puff of smoke, usually on the first pull and nothing after that. It has always been maintained properly and has been used frequently almost all year around on the Eastern shore of Maryland. Please help! Any suggestions???
