I have a 1986 115 "tower of power" It starts and Idles fine, but I have been having a stumble from just above idle. It seams to do it after a higher speeds fun, then you stop and idle or not for a min (kids getting back on tube or such) then when going to power up it bogs and dies. It can be overcome by careful use of the throttle but you deffinlatly have to play with it to get it to pick up revs. Revs up in neutral, didn't bog when I first took off and warmed up the boat yesterday. (wasnt run for about a month)
I have put on a new plunger and it pumped up hard the first time, but afer we had run the boat, back a few hours later the bulb seamed to not get firm again (feul kept getting pushed back to the tank) Last year the boat accelerated fine but didnt idle the best, this year I put some sea foam in the feul and had to adjust the pilots back a bit after running it, now it idles great, but has devleoped this bog after running. It has a 20 gal on board tank. I would almost think it would be water in the feul but we had quite a bit of full throttle running and would have expected any water to have been picked up by the main not the mid circut.
I am a vintage motorcycle guy and restore my own bikes but I have not dont alot of boat work so I dont know the carb internals on outboards as such
Cheers Chris
Cheers Chris
