Have a 2006 Mercury 115 hp 4 Stroke that just lost shifting in forward or reverse. Motor was running a good 20 minutes before. It stalled once and I was able to start it up. But once I have the controls in forward, the boat did not move and the prop is not spinning. Have a buddy pop the cowl and look into the linkage when I try to shift, cable and linkage seems fine.
I have read and try searching the forum for the same issue but nothing too similar. Believe now I have to pull the lower unit. There are 5 bolts plus the Trim Tab that I know off. Just like confirmation as to the controls.
1) Should the shifter control be in Neutral or Forward prior to dropping the LU?
2) Is there any linkage that required removal or to be disconnected prior to dropping lower unit.
3) How does one turn the drive shaft once lower unit is out?
4) Does turning the prop spins the drive shaft?
5) Aligning shifter shaft?
Any assistance would be appreciated.
