79calglass
- Aug 30, 2011
- 20
I was cruising fine when suddenly my motor began to struggle as if there was resistance internally. Then it died. I tried to restart it and the flywheel had a lot of resistance and it struggled to turn over, as though the battery was low or the starter was weak. Charged up the battery and let it sit for a few days. It fired up but it was very weak when it turned over as though the battery was low. It ran and I took it for a spin on the river. After a few minutes of cruising it made a ticking noise and choked and died. I've tried spinning the flywheel by hand and there is a lot of resistance. I've removed plugs and it spins easier but still to much resistance to fire up. Any ideas what the problem could be?
I had issues with the starter, it wouldn't engage at times, wd 40 solved the problem. I don't think my starter or battery is weak. I believe the flywheel is sticky for some reason. What would cause this?
Thanks, any help would be appreciated.
