Re: 1993 200HP Mercury XRI - Starter/Flywheel
It's in the starter. The starter has two "actions". The bendix is the spiral cut gear that makes the drive gear move up and engage the flywheel ring gear. Then the motor itself turns the flywheel and waa-laa, you are running. If you are getting the bendix to kick the gear up to the flywheel but it won't stay up, your starter motor isn't giving enough oomph to do so. If you hold it up there it works, right? You might even try lubing the bendix- spray some PBlaster or WD in there and try it. The gear should have some very light grease on it but if it is sticky it may do what you are having issues with. If that doesn't help, your starter is the issue. If you have damage or an out-of-round issue with the flywheel enough to not allow the gears to engage you'd have quite the vibration when the engine was running.
